SW materials and Configs
Is it possible to have configuration specific materials in SW04?
I would like to edit the material seperatly for different configurations.
For instance have one config set as Grey Iron and another as wood such as with a casting and a pattern.
RE: SW materials and Configs
You can't control Materials per config.
You can however control Textures per config, not that that will help you much.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
SW 2005 does allow configuration specific materials!  Yaaah.
THanks, I was hoping that I was just overlooking something.
05 sounds sweet so far. Hopefully we can get running it before too long.:)
