Driving Sketch Better than equation
Do you know about those call driving sketch ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Driving Sketch Better than equation
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
All following features don’t have any dimensions.
With new designs, I normally make one or two "control line" sketches. For instance, the main profile of an extruded hinge will be a stand-alone sketch. The first extrude feature's sketch will reference the control line sketch using "Convert Entities". Later features reference the control line sketches instead of model edges whenever possible.
This may sound like a pain in the arse, but it saves a lot of trouble in the long run. I find it's easier to manage changes in models when they are constructed in this fashion.
http://www.EsoxRepublic.com
Now that you have those 3 driving sketches (top, front & write) you can create a design table that drives your driving sketches.
In other words when you want to change something you look only in one place your design table.
Scott Baugh, CSWP
Scott Baugh, CSWP
Scott Baugh, CSWP
I only use DT in parts.
