Adding Extension to Written File
I have a program that reads the name of a file and from the name creates a new file.  It's done by setting the name of the original file as a character variable, x, and then substituting that variable into "FILE=x"
Is there a way to add .txt or .xls or something similar after the x?
RE: Adding Extension to Written File
Yes there is!
Just add   //'.txt'  after the string variable which will concatenate the text string '.txt' on to your string variable
FILE=x//'txt'
You might want that to be something like....
File= TRIM(x)//'.txt'
The above will get rid of the excess spaces at the end of 'x'.  Also... you must make sure you declare x and File to be Character variables of sufficient length.
Dan
www.dtware.com
