Very Very Thick line at section view on V5R13
During generating a section view, ugly thick line is generated. How to correct that? If there are some way to fix the problem permanantly, plz, let me know. Thank you.
RE: Very Very Thick line at section view on V5R13
However, I mean not the Section Arrows. If I install a bunch of bolts using Reused Pattern, I wanna see the section view of the area installed the bolts. After section cut, some lines of the bolts are so much thick.TT
Have you ever get the ugly lines?
Thank you.
Use the up arrow key while over the area fill in question this will bring up the sort selection feature which will give you a list of what is available.
Catiajim is correct.^^. It's very helpful.
But, why IBM do not correct the bug...??
The work treating the lines is, I think, time bug.
