lubricant to increase PV value of Aluminum bronze
We are trying to come up with a solution to a bushing problem. While reviewing a bushing catalog I found that they rate there materials based on the PV values. In the book they state that PV values can be increased by addition of the correct lubricants. I'm also interested in possibly using something that is self lubricating.
I need something that will withstand a Velocity of V=210 fpm, P= 2500 psi (force that pin puts on projected area of bushing), and a pv value around 450,000.
Any ideas?
Schroyer
Any ideas?
Schroyer
RE: lubricant to increase PV value of Aluminum bronze
Good luck.
It will certianly never happen with a continuous duty cycle and a self lubricating bearing. At least not in my experience. Self lubricating bearings always work better with lubrication. If you find something that works please let us know!
