Standard Steel Section Database
Can someone direct me to a site where I can download a current (and free) database of the various steel sections?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Standard Steel Section Database
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
looking for one in ASCII format that has all the properties of the section that I can use for a program that I'm writing.
Carl Bauer
www.bauerconsultbotswana.com
It's easy to adapt the work to accommodate any series of sections. In general with engineering data programs, I input the files in ASCII and re-write them in binary for programs to use... I have 3 incomplete North American databases and all of them have slight variations... as well as missing some sections, etc. The program is a front end for another program and presently calculates Class of section, Lu, moment resistance, plastic moment resistance, etc. based on the Canadian S16 steel code. Presently use it as a quick 'pop up' for sizing members.
http://www.lanxun.com/pce
Thanks for the offer... I downloaded a couple of files and reviewed the data. I need a complete set of data; my present database has the following type of info in it:
IDesig, d, b, Web t, Flange t, k, k1, A, J,
y, Ix, Sy, Sx, ry, rx, MDesig (added), Surface Area, Zx, Zy, Cw, Source (added),
and for a typical section: W36x300, 36.74,
16.655, 0.945, 1.68, 2.8125, 1.5, 88.3,
64.2, 1300, 20300, 156, 1110, 3.83, 15.2,
W920x446, 11.5, 1260, 241, 399000, and a string key for source.
Problem is that of the 3 databases I have, they all have some slight variation, either values or designation.
For other rolled shapes S, M, C, etc., there are some missing values. I understand that ASTM or one of the standards organization has a listing of standard sizes and properties. It is this data that I require.
Taro:
I thought that one of the roles of the AISC was to promote the use of steel <G>. I thought some other agency would establish a listing of the sections and properties that the AISC would follow.
http://24.7.86.152/group/seaint/2001a/msg00196.html
Thanks. It is very likely then that the AISC has copyrighted the data in their section database, just as you or I can create a database of section properties for dimensioned lumber (2x4, etc.) and this can be copyrighted.
I will check into the legal issues. That may explain the slight variations I have in the 3 sets of data.
Chelo_1:
I program in several languages and create little 'knock-offs'; these are programs that help me with day to day stuff... I usually do a fairly comprehensive 'front end' so that I can re-use components.
If you have an unrelated question, you should start it as a new topic. I'm not comfortable with providing preliminary designs in this forum, but will do it this time only.
If I read you correctly, you want to support an entire second floor on a beam spanning 27'. The beam will be supporting 13.5' tributary width of floor loading. Typical live load in this area is 40 psf and I would assume that the dead load is approximately 8 to 10 psf. Your jurisdiction may include a fixed load for partition loading? A local building inspector should be able to assist regarding the loading information. I'll do a preliminary size for the members based on the above criteria, but you should seek local professional assistance for a final design. PSL, LVL and steel may have different strengths depending on the area.
An LVL or PSL beam may be out of the question for that span and may have a depth of 20" or so... and even a steel beam could be 14" or 16" deep. Can you have any interior supports; these would likely have to be taken to the basement and a footing.
(later)
A 6.19x19 2.0E PSL with 6x6 posts at each end will have a live load deflection of 0.88" and a total load deflection of 1.3" and it will likely be bouncy. Although a W14x22 provides the necessary strength, the equivalent steel beam for deflections would be a W14x26 (Grade 44ksi/300MPa). A W16x26 can be used (approx same weight but stiffer) and steel beams should be supported on steel columns. You could have problems with partitions cracking, vibration, etc.
This is a preliminary design only and should not be used for construction. To reiterate, seek professional help in your area. The service of providing this type of information assuming the problem is as simple as you've stated (there may be more to it than you've stated), in a letter form would cost upwards of $100 locally; prices may vary in your area.
