Grinding and Corrosion Resistance
Can changing the speed during a diamond turning (cutting) operation on 400-series stainless steel change its corrosion resistance? It seem if we cut at a higher rpm the tool is more suseptable to acids.
RE: Grinding and Corrosion Resistance
A good alternative is CBN tools.
Wet grinding causes the least loss of corrosion resistance.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
