Strength of unistrut section
I been trying to figure out the strength of a channel shape unistrut bar bolted on a rolling load table, which will be subjected to a concentrated load applied through a ball screw. Would some one help me get through this?
RE: Strength of unistrut section
Can you give more information ie describe your actual set up. I assume the channel is open side up and therefore the back is completed supported by the table.
So what size and thickness is the unistrut and length, also where abouts is the load applied.
regards desertfox
http://unistrut.com/literature
