blue dimension in assembly
I had an assembly.  When I redrew extruded cut in the assembly, the dimension changed to blue instead of pink.  I would like to know the difference between blue and pink dimension.  By the way guys, I have done my course on CATIA not Solidworks.  Thank you.
RE: blue dimension in assembly
You have to check your system options for colors, as someone might have changed the defaults.
Normally, blue dims are for extrusions and black are for sketch entities.  I haven't seen pink dims.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Pink is the default color for a dimension that is in a Design table.
Blue is the default color for a dimension that represent a feature (Cut, Boss, Revolve, etc..)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Thanks Scott, I don't get opprotunities to use Design Tables.
Ray Reynolds
