Solidworks to Solid Edge
Can Solid Edge open Solidworks files or do I have to convert the files to a .sat, .step, .igs to open in Solid Edge?
RE: Solidworks to Solid Edge
SE user stand point - If you click File\open and change the files of type - do you see SW in there? If not, then yes you will need to convert them.
SW user stand point - If your doing this for a customer you should ask them if SE opens SW files. with the same process above.
You could try contact SE and asking them directly too - http://www.solidedge.com/
I know that probably wasn't alot of help...
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
No, SE does not open SW files directly.  Parasolid is the best.
--Scott
For some pleasure reading, try FAQ731-376
