Sweep section or guide curves are ambiguous
Hi All
When trying to extrude a sketch I get the above error message.
Any idea why?
Dave
RE: Sweep section or guide curves are ambiguous
How are you extruding; i.e. vector direction, until a face, etc.?
Describe your sketch...is it an open string, closed string, contain splines, fully constrained?  Did you import the curves & add them to a sketch?  Did you create the curves in sketcher or add them to sketcher after importing or creating in Modeling?
I've only seen that message when curves are not completely lying on the same plane, like if you imported some curves that were all connected in Autocad, & tried to use them in UG without 'cleaning' them up a bit (redefine fillets, re-trim corners, etc.).  Or if some of the curves laid flat on their creation plane & others were a bit skewed.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I would say that you have curves overlapping each other. Check so each joint just have one point.
