Cellphone antenna with narrow beamwidth
I am looking for an antenna which is intendet to be used to detect illegal cellphones in jailhouses. The policeman is walking up and down the corridors with the antenna and a small specrum analyzer to look for rf-signals (900-2500MHz). To lower the risk of a wrong indication, the antenna should have a narrow beamwidth or should be switchable to a narrow beamwidth. Otherwise the indication would be too rough. It is important to prevent inspections and "sweeping actions" due to false indications.
One of my ideas is to use these small ceramic patch antennas built into the phones. If I arrange the for an array of about 3x3 elements, I can change the beamwidth by switching the phasing lines.
Who knows which company ofers such antennas?
Who has a better or just another idea?
RE: Cellphone antenna with narrow beamwidth
http://www.interceptinvestigations.com/CounterSurv...
What you'll need to do is to find one that can detect cellphones that are turned off, which requires a combination active/passive detector.
TTFN
Have you considered just jamming the cell phones - I've read that cell phone jammers are more-or-less commercially available (not sure if they're totally legal). Seems like an easier approach.
http://cellantenna.com/CJAM/cjam.htm
Not as much 'fun' as tracking them down and catching them in the act, but certainly a ~lot~ less work.
Patch antennas won't cover that frequency bandwidth, much too wide. You need something else, bicone or notch type antenna.
Narrow beamwidth, if 50 degrees x 50 degrees is an antenna 12" square, if you want 25x25 degrees, it's 24" square. So do you really need narrow beamwidth? You probably want to hide it under clothing if the answer is yes and you can't make it flat for low cost.
You could make a very low cost system, simple antenna and a low cost wide open detector to find a cell phone, about $20 in parts if you plan to walk by the cells to detect it.
Jamming is a good idea, and very simple. Europeans use cell jammers but they're illegal in the US.
If you just need a simple antenna, I made one that covers that range, wide beamwidth though. A simple notch antenna, piece of metal with a slot in it, and a cable across the slot, size is 4"x6"x 0.03" in size, weighs about 5 ounces.
kch
The frequency range should take care of the next inventions on the cellphone market like UMTS.
Jamming is impossible. This jail is inside a big (well known) city, not ouside in the countryside.
Just by the way, I suppose that reflections might be not so very much misleading. The door of each cell is made from wood! So each cell is like a big cavity.
kch
