Dimension Coloring
Dimension Coloring
Two simple questions
Where do I change the color of a dimension or note in a drawing? and can I set it to keep using that color for new dimensions?
RE: Dimension Coloring
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Brian Titus, CSWP
Technical Manager - GEI technology
Now all new drawings will have those dimensions that you add placed on that layer.
Jason Capriotti
Smith & Nephew, Inc.
