Toolbox bearing numbers
I know I must be missing something but can any one tell me how to connect an manufacturers part number to a ball bearing inserted from the tool box (for instance Radial Ball ((AFBMA 20.1)). And how do I determine what the size is for instance a toolbox definition for the size 30-17 gives me a bearing with a 17mm ID and a 35mm O.D, I need a mfg like INA, SKF, NTN, TORRINGTON, etc. I know I must be very slooooow today.
TAP
TAP
RE: Toolbox bearing numbers
Check there.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Scott thanks for replying. You are most helpful to all of us.
TAP
2) Do you have an example bearing that shows this? Please list the bearing and I'll take a look at min here.
Other then above, I'm not sure what excatly your after.
Scott Baugh, CSWP
TAP
http://bearings.globalspec.com/Specifications/Mech...
GlobalSpec is a SW /3D Content Central search partner.
For a more thorough explanation, you can buy the actual standards as downloadable PDF files from sources such as:
www.techstreet.com
or
www.global.ihs.com
Otherwise, larger manufacturers like SKF and Timken will have a cross-reference chart in the back of their master catalog or on their website.
FYI
DesignSmith
www.DesignSmith-Services.com
