wildfire2 added views no type option available
I have put an general front view, and I want to add a projection ortho view, but when I use the same icon, shows the dialog box but I can Change the Type view because it isn't available.
This is normal and I have to add projection or Detail views by >Insert/Drawing View/"Option"<?
Or clicking 3d button over general view and choice "Add projection view"?
I know that the last two options are allways availables.
RE: wildfire2 added views no type option available
Click view, right mouse, scroll down to projected view.  Highlighted box will appear where you can place view.  To create aux view, right mouse to properties and follow thru the plane choices.
