Heat Transfer Consultant Needed
Does anyone know of a Consultant or Firm that has expertise in calculating heat transfer and/or temperature profiles of a complex "fin"?  Specifically, this application involves steel beams that penetrate a building's insulation envelope and are welded to structural steel.  Preferably someone located in the Northwest USA or Alaska and someone experienced in Arctic Engineering or techniques.
RE: Heat Transfer Consultant Needed
DEAR RUSSMECH:  I WOULD LIKE TO TALK TO YOU FURTHER ABOUT YOUR CONCERNS ON THIS ASSIGNMENT.  PLEASE CONTACT ME WITH YOUR NAME AND PHONE NUMBER AT WSEC1@EARTHLINK.NET OR THROUGH MY WEBSITE AT WWW.WSEC1.COM
THANK YOU
DAVE HALL
While many can analyze fins--What is a complex fin?
russmech,
i know several heat xsfer specialists (somewhat of a generalist myself) and will provide contact information upon request; but not via this forum. please advise if interested. oh! i'm located in ak.
something to ponder...
without knowing details of complex fin and i'm imagining a steel beam exposed to ambient conditions that penetrates bldg insulation envelope, i would imagine the concern is heat xsfer by conduction. is it possible to install a thermal break/barrier between complex fin & bldg to minimize heat xsfer?
lastly, i believe, for the most part, that since you posted a question in this forum and are requesting assistance/direction from fellow engr's, that you may receive beneficial responses from skilled engr's if given the opportunity. this posting may receive a more skilled audience if posted in heat xsfer forum as well.
good luck!
-pmover
