Can't Check-in part created FROM Toolbox geometry to PDMWorks
Hi Everyone,
I have a couple of special fasteners that I created from Toolbox geometry in order to save a little time.  Unfortunately I am now unable to check-in these files to the PDMWorks vault because of an administrative setting that disallows check-in of Toolbox components.  In other words even though these file copies have been modified they are still being recognized as Toolbox components.
Does anyone know of a way to remedy this situation short of re-creating the components from scratch?  I am assuming that there is some kind of flag within the file denoting the fact that it was originally created by Toolbox but I'm not having any luck in finding it.
Chris Gervais
Sr. Mechanical Designer
Lytron Corp.
RE: Can't Check-in part created FROM Toolbox geometry to PDMWorks
Your Admin must have TB turned on in the PDMworks. SW Doesn't recommend that you have this option turned on for TB.
Check with your Admin on this issue.
If you have TB on your Local or network drive you can add your fasteners to TB directly.
Go to TB on the drop down menus. There you will see "Add my parts Wizard..." Foloow the menus from there.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
You are correct.  There is an internal flag that is set that designates a file as a "Toolbox" part.
Luckily, SolidWorks includes a utility to set (and UNSET) this flag.
The utility is located in the directory:
C:\Program Files\SolidWorks\Toolbox\data utilities
and is called:
sldsetdocprop.exe
Use this to fix your problem.
Brian Titus, CSWP
Technical Manager - GEI technology
