EXCEL WORKSHT. NOT PRINTING
Have inserted excel b.o.m. worksheet. When dwg. is printed everything is fine except the b.o.m. doesn't print. Any ideas? Thanks
RE: EXCEL WORKSHT. NOT PRINTING
Do not use your usual printing method.  You will have to print using "MS Print Manager" instead.  It's the same if you place a .jpg picture in the field of the drawing.  You would then have to print using "print manager".
The "MS Print Manager" should be your default destination.
Hope this helps,
NbLYLYDdy
