File renaming
File renaming
Hello,UG gurus!
I'm asking this question first in here and maybe afterwards in UG BBS.
In UGII directory there is ug_edit_part_names which you can use to rename parts and to list references.Since almost everyone suggests using master model approach for performance reasons(separate file for drawing) I'm unable to locate drawing file and rename master file using above mentioned utility.
Any explanations or suggestions?
Hopefully problem is understandable.
Henry
Henry
RE: File renaming
RE: File renaming
RE: File renaming
I think Cloning can only pick up non-masters (drawings) under Teamcenter Engineering (IMAN). Under straight native NX you are out of luck.
If you have a standard naming convention; i.e. you can infer the drawing name given the model name, you could write a routine to automatically open drawings for a model or an entire assembly of models. Then you could use the free "Save All As" utility I wrote (see www.SolidNX.com/download) to rename all loaded parts.
Cheers,
-MikeN
SolidNX
