bad definition when loading Complex Linetype
I have made some shape files and compiled them. I then tried to incorporate the shapes into some new linetypes but, when I try to load the linetype I get an error "bad definition on Lin1Signal at line 29 of file z:\acad14\linetypes\pid.lin." Here are lines 28&29 from my complex linetype definition.
*lin1Signal, --- [LIN1] --- [LIN1] --- [LIN1] (line 28)
A,.25,-.1,[lin1,pid.shx,X=-.1,S=.1],-.1,1 (this is line 29)
Lin1 is the name of the character defined in my pid.shp file and pid.shx is the compiled version of my pid.shp file. I can use the pid.shx file without any problems in a drawing but, I can not get it to work in my linetype. Anyone know what the problem is? These are the results when I tried substituting other fonts that came with autocad. (I have tried the CIRC1 using ltypeshp.shx in place of lin1 and pid.shx not changing anything else and it works.)(While using the kexc using gdt.shx gives me the same error as if I were using the pid.shx font file)The strange thing about ltypeshp.shx (the one that works) is that I can not load the font file from the style dialog box but, the other 2 I can even though it is in my autocad\support directory.
RE: bad definition when loading Complex Linetype
Use capital letters for character name. Don't know if it needs to be, but seems that's the standard used in acad.lin.
