graphics problem w/ edrawings on win 2k server
when viewing solidworks files with edrawing viewer on terminal servers on a windows 2000 server the image is "fuzzy". I have been told this is because win 2k ts is limited to 256 colors at the end user's terminal and to fix this I need to upgrade to a win 2003 server. Does anyone know of a less expensive solution?
RE: graphics problem w/ edrawings on win 2k server
If your only running 256 colors, then I would tend to agree with this. You need more than 256 colors to view the images with good clarity.
Is it not possible to just move up to True or High bit colors instead?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
