Black tin Oxide Deposit on Babbitt Bearings
Does anybody have any references to any research work or investigations on the causes and effects of the black tin-oxide deposits frequently found on small areas of the surface of babbitted bearings?
RE: Black tin Oxide Deposit on Babbitt Bearings
unclesyd - thanks I already found that one when I did a search earlier.
I have two other articles that say essentially the same thing.
I have seen this problem on several babbitt bearings where there was water, not saltwater, present.  These bearings were in  turbines and centrifugal compressors.  Two of the instances were on a popular make air compressor where the steam turbine is directly coupled to the compressor and share a common oil sump.  As you probably know we get steam/condensate by the carbons and into the oil. The water has a Ph 5-6 and thoroughly oxygenated.  We don't see this on every turnaround but about a quarter of the time.  These machines have been running this way for 25 years.
I see the effect quite a lot on dry units and it appears to be largely a function of fretting damage during transport.
