Clamping Force
Clamping Force
Clamping Force
This is a simple clamping force problem that I just want to be sure I am envisioning it correctly.  If you have a plate with one bolt in it torqued to a value X, the clamping force will be Y.  If you then add 3 more bolts torquing them all to the same value X, the total clamping force will still be Y since they are acting in parallel (in other words, it is distributing the clamping force along the plate rather than increasing the total clamping force).  Is that correct?
RE: Clamping Force
Correct. The clamping force is independent of the number of fasteners. The service load on each fastener is a different matter, and would depend on the type of loading, clamping force per fastener and number of fasteners.
RE: Clamping Force
Where are you measuring the "clamping force"?  If you are trying to separate the plate from another piece, you must extert 4Y (assuming an ideal system).
Cory
RE: Clamping Force
The exact problem I am having is dealing with a clamp band.  The band is is broken into two 180 degree sections with a bolt torqued to X on each side.  I was trying to solve for the vertical clamping force since clamp band is tapered on the inside.  My approach was as follows
sigma(hoop)* Clamp Band Cross-Sectional Area = Internal Pressure * Area the pressure is acting on
Therefore,
Clamping Force = Internal Pressure * Area the pressure is acting on
I then solved for the internal pressure, did some good ole trig to get the vertical component, and called it a day.  My concern is if the Clamping Force I use on the left side of the equation is suppose to be double since there are two bolts.  I have talked myself into say yes and no.  If you draw the FBD it appears as if you need to take 2 * the clamping force since you have one on each side.  But realistically, I don't think that is the case but cannot prove it.  If this does not make sense, ignore the tapered part and solve it as a simple clamp band and determine the resulting clamping force if bolted together.  Thanks for your help.
RE: Clamping Force
If you are assuming the fasteners are not prestressed, then the resisting force each one exerts to withstand the internal pressure is 0.5 * Clamping Force (as defined above).
Cory
