***Advanced Option when opening models***
Hello all
An easy question here today.
What does the Advanced tick box do when opening drawings etc?
Jim
NZ
Jim
NZ
RE: ***Advanced Option when opening models***
Advanced - Opens the Configure Document dialog box (Assemblies only)
If you want to know what Configure Document is then you will need to look in your help because it is hyperlinked.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
