Colours of constraints in sketch
Hi Again
Could someone please list the colours of constraints and their meaning.
Dave
Dave
Colours of constraints in sketchColours of constraints in sketch(OP)
Hi Again
Could someone please list the colours of constraints and their meaning. Dave Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Colours of constraints in sketch
Cyan
Curves that are part of a sketch are by default colored cyan.
Green
Curves that are not part of a sketch are by default colored green. Sketch dimensions that do not cause a conflict with other dimension constraints are also colored green.
Yellow
Sketch geomtry and any dimensional constraints associated with it that are overconstrained are colored yellow. This occurs when you apply more constraints to a curve or vertex than are needed to control it.
Degree of Freedom Arrows, which indicate vertex points that are under constrained, are also colored yellow.
Pink
As you add constraints to a sketch they are evaluated, and if confilicts between other constraints are found by the system the color of the conflicting dimensions are changed from green to pink, and the sketch geometry is changed to gray. This visual feedback indicates that the sketch cannot be solved given the current constraints.
White
Dimensions that you convert from active to reference using Convert To/From Reference change from green to white.
Gray
Sketch geometry that you convert from active to reference using Convert To/From Reference change to gray, phantom line. Sketch geometry may also change its color to gray if conflicts exist with its dimension constraints (see Pink, above).
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
