Welder Qualification D1.1
Reference table 4.8 AWS D1.1 2000
For the fillet weld qualification test (plate), the table indicates that this also qualifies for production pipe fillet welds.
So if a welder qualified on the fillet weld plate test, would he be qualified to weld flanges onto the ends of 4" pipe?
RE: Welder Qualification D1.1
Not very many applications where you'll have a longitudinal fillet weld for pipe!
Why not use the pipe fillet qualification? That will suffice for plate, pipe, and box tubes.
