ALPHA CABIN CONSTRUCTION
Hi To all,
We would like to construct or resell a alpha cabin to one of our client.  Could you please help us to find detailed information to construct alpha cabin (other than the one stated on Rieters web pages) or could you please advise an engineering company that can construct one?
Sincerely
vozgul
RE: ALPHA CABIN CONSTRUCTION
Which is it?
Are you looking to construct an Alpha Cabin, or sell one?
You do know, don't you,  that an Alpha Cabin is simply a small reverb room, used by Rieter primarily for testing parts as opposed to large samples of materials?
The only way you could construct an "Alpha Cabin" as such would be to have agreement from Rieter that you'd ultimately be able to conduct correlation studies to determine that your cabin gives the same results as theirs.
Failing in that,  just build your own small reverb room and correlate the results to a standard reverb room.
