Text format in revision block
Hi, friends
I create tile block using Frame creation command.
After that i create revision block also using frame create command
I need change format text from SSS2 to Ariel, but I do not know how.
Can you help me
RE: Text format in revision block
Start off by double clicking the table to edit it. Then highlight the cell(s)you want to change (or the entire table) and then hit ALT & ENTER at the same time, this will bring up the text properties dialog.
