Insulator for Capacitor
I have a question regarding capacitors in general.
Theoretically a capacitor consists of two metal plates in parallell. In the ideal case where there is vaccum between the plates there should be infinite resistance between the two plate.
I am trying to make a capacitor with two aluminium foil and a plastic foil between them. While checking for a possible short circuit I discovered that there is about 20MOHM or more between the plates.
Is this a short circuit or is the resistance of the plastic foil?
any idea about a better insulator? What is the resistivity of kitchen plastic foil?
Tom
Tom
RE: Insulator for Capacitor
Plasic "Saran" wrap is made of polyvinylidene chloride. I wasn't able to find electrical resisitivity data in a few minutes of googling. You might have better luck.
Mylar is a very good insulator and commonly used in capacitors. It is made from polyester.
