Reject Paint Marking System
I am looking for a fairly inexpensive painting system to dot mark rejects. There are four different reasons that a part can be rejected, but one reject bin, paint marking would make for easier sorting of the rework. I need the system to be reliable about not clogging up since it will not be used on a regular basis except for rejects.
Any suggestions would be helpful!!!!
Thank you!
Thank you!
RE: Reject Paint Marking System
http://www.jantech.com/dotmarker.htm
I have used products from the second link with good luck.
Bob
One thing that we have used for simple dots is an off the shelf marker attached to a cylinder 'head'. When they dry out, which is often a new one is very inexpensive. If a custom mark is required, there are companies who will make a custom die for a setup charge and the markers are then reasonably priced.
Hope this helps.
