suppliers of thin film attenuators
i think i'm going to give up make my own. who's a good supplier of chip attenuators, 2 watts, 0-20ghz? 1db, 6db, etc
thanks,
RE: suppliers of thin film attenuators
You don't specify the application.  Is this for surface mount or installation in a coaxial type attenuator?
Have you tried EMC?
From their website:
EMC Technology’s attenuators are available in a low power chip package. The power ratings range from 0.1 to 2 watts. The attenuation values range from 1 dB to 20 dB. The terminals of EMC chip attenuators are made with thick film base material that is nickel plated and solder coated (Lead free version are available). The resistive element is thin film offering superior electrical performance.
http://www.emct.com/microwavepassivecomponents-s10...
or Nanowavetech  http://www.nanowavetech.com/DataSheets/Passives/At...
I have had Micrometrics (Londonderry NH) make them for me
Good luck
David
thanks dave!
application is a coaxial attenuator; we plan to mount a surface mount chip attenuator on an alumina substrate.
i didnt know nanowave or micrometrics were in the business; i'll go check them out.  thanks!
bob
