Aligning Section View Axes (not drawing view)
I'm running SW2004 SP2.1, and trying to get a certain section view of an assembly.
My problem is that when I start the section view command, the orientation of the cutting plane is not quite right. If I rotate the plane around, it moves away from the center of my part. My part is oriented to and centered on the assembly origin, but the rotation axis of the cutting plane isn't.
Is there a way to position the cutting plane axis relative to the origin or some other arbitrary feature?
-wes
-wes
RE: Aligning Section View Axes (not drawing view)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
