AutoCAD 2002 :: Paperspace Zooming:: HEEEEEEEELP
Using CAD 2002.  After laying out vports in paperspace I am trying to maneuver back and forth between between windows and the computer is automatically refresshing all vports to Zoom All.
Help Please... Clients in office Wednesday HEEEEEEEEEEEELP Please!
RE: AutoCAD 2002 :: Paperspace Zooming:: HEEEEEEEELP
Maybe: Thread555-77804
Lothar
ADT 2004
ACAD 2002
While in paperspace, and maneuvering around the viewport windows into modelspace, you will want to lock the viewport scales first. You can click on a viewport and then enter "ch" (change) on the command line. You can then select Display Locked to see the effects of locking the viewport.
"Everybody is ignorant, only on different subjects." — Will Rogers
I modified my Acad.lsp file to include the following:  Each assumes that the viewports are on layer DefPoints or VPLayer (or layers starting with Def and VP).  I think of them as (V)iewport(L)ock, (V)iewport(U)nlock, (V)iewport(F)reeze and (V)iewport(T)haw
(DEFUN C:VL ()  ; Lock all viewports
 (COMMAND "LAYER" "THAW" "DEF*,VP*" "")
 (COMMAND "MVIEW" "LOCK" "ON" "ALL" "")
 (COMMAND "LAYER" "FREEZE" "DEF*,VP*" "")
(DEFUN C:VU ()  ; Unlock all viewports
 (COMMAND "MVIEW" "LOCK" "Off" "ALL" "")
(DEFUN C:VT ()   ; Thaw the viewport layers
(DEFUN C:VF ()  ; Freeze the viewport layers
