Photoworks memory read error
Loading Photoworks 2 add-in causes "The Instruction 0x1001d5 referenced memory at 0x000001ac. The memory could not be read". Rest of Solidworks 2004 SP4 is OK. Any ideas?
AMD Athlon 1700
768MB ram
Biostar Mobo
Via chipset (latest drivers)
Quadro card
Thanks !!
RE: Photoworks memory read error
This would seem to be a problem in windows more than SW. try looking that referenced memory hexidecimal up at www.microsoft.com maybe you will get a hit on it. Anytime you get an error of that nature Windows is to blame versus the App.
I get the same sort of error when I close my IE6. Windows is to blame but since it's only IE I'm not to concerned with it.
You could try to do a repair or reinstall, but I'm not sure if eitehr of those help you. Although a clean uninstall and reinstall might.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
