Exporting to DWG file
I am trying to export a solidworks drawing to a DWG file that will open in autoCADD. This drawing has multi views and sheets. The steps I have been using is:
File
Save As
Save as type: Dwg
Then I set my options to the correct version of AutoCadd and set the scale.
This creates an AutoCadd file. When I open the new file all that shows up are center lines and dimensions. Can anyone help?
File
Save As
Save as type: Dwg
RE: Exporting to DWG file
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
