pen assignments
pen assignments
pen assignments
hello,
i've written an vba-program for automatic plotting in autocad. The only thing i don't know how to do is programming for assigning a ctb-file.
does anyone know how it works?
mvgr
RE: pen assignments
Here is a snippet of ours, it may be a help...
If ThisDrawing.ActiveSpace = acModelSpace Then
    Set acObjSpace = ThisDrawing.ModelSpace
Else
    Set acObjSpace = ThisDrawing.PaperSpace
End If
Set acLayout = acObjSpace.Layout
    acLayout.RefreshPlotDeviceInfo 'Needed since we changed the plotter support paths
With acLayout
        .ConfigName = strPrinter 'set printer first so options exist
        .StyleSheet = strStyle
        .CanonicalMediaName = strPaperName
        .PlotType = acPltType 'must be set before centerplot property
        .PlotOrigin = dblPltOrigin 'this must come before centerplot
        .CenterPlot = blnCtr
        .PaperUnits = acMillimeters 'default----
        .PlotRotation = acPlotRota
        .StandardScale = dblPaperScl
        .UseStandardScale = True
        SetPlotParameters = True
    End With
"Everybody is ignorant, only on different subjects." — Will Rogers
