part not a valid version
I am new to UG and when I try to open a drawing in NX2 I get the following error: part not a valid version of component part. I know I have fixed this before but it was 5 months ago and I dont remember what I did.
Chris
RE: part not a valid version
Open the assembly (drawing) with No Components
Use the Open As in the ANT on the component name
Select the component you want
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I am coming across the same error. However, when I try to use "open componet as" I get the error "This part is not a version of the original". These should be valid, they came directly from G.M. Any suggestions?
Can't explain why, but we experience this as well. It usually suffices to remove the component from the assembly and then add it back in. It should show up under latest revision.
Anoter option is to right click the component in the ANT and use Substitute the Remove and Add.  This works also.
Ross Parpart
Product Design Engineer
www.decoma.com
You can also try to load the component before loading the assembly.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
Ingersoll-Rand
Thanks. That worked for me.
Another solution is to toggle on allow substitutions in your load options.
Mark Benson
CAD Support Engineer
