Modsoft Programming Software Help
I'm using Modsoft Programming Software.
I'm viewing a program offline and only items visible on screen are the ladder logic & I/O address below each element (exm: 000019).
I was thinking there was a way to display the description for each address above elements, but can't figure out the key combination.
Any Help?
Thanks!!!
RE: Modsoft Programming Software Help
You wont be able to do that if you pulled the program from the processor. That is only viewable if you have the origioanl program on the puter you are using..
