Keyboard cleaning
Keyboard cleaning
Keyboard cleaning
Anyone knows an easy and fast way ?
<nbucska@pcperipherals DOT com> subj: eng-tips
RE: Keyboard cleaning
I usually shake mine upside down a bit to get all the chip crumbs out, followed up by a good vacuumming with a brush attachment. Finally a good wet wipe down with a rag and a cleaner that is safe for the plastic and test (simple green, diluted alcohol, etc).
Works for DOS and Windows PC, too.
Have fun
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
A long time ago I had an old keyboard that I would just unplug and soak in warm water.  Never did die on me.  In fact, I still have it.  Don't know that I would try that any more with one, though!
I just cleaned mine the other day after a move.  Apparently this keyboard had been around for awhile because every time I used it I felt I had to wash my hands afterward.  I also had very long hairs sticking out in some places.
I went ahead and cleaned it the right way, popping off each key with a screwdriver (very easy) and cleaned each key separately while turning it over and hitting it to let all the interesting stuff fall out.  Once I put it back together it looked good as new.
Pull out all the keys (can use screw driver) and wash them in a bucket of soap water. Vacuum clean the keyborad while keys dry up. Now, its the tricky part - plug in the keys in the right place!!
Throw it away, and go to Fry's or CompUSA when they have a sale going on, and get a new one for $2... Just a though, probly not what you are expecting to hear though...
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
And for 15 EURO you have a state of the art Logitech keybord. Clean of course ; )
