Custom Hole wizard profiles
When you add a custom profile for a tapped hole to the hole wizard custom data base, how do you get the callout to show on the print when you use "Add a hole callout" command??
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Custom Hole wizard profiles
Till this is fixed you have to do it manually.
FYI - You did place the data in your "Thread data" DB and not just under Hole wizard... didn't you?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Scott Baugh, CSWP
