3-phase transformer question
For a Delta-Wye connected transformer, will non-balanced primary voltage be transformed through the transformer proportionally, or does the core-form construction re-balance the line?
RE: 3-phase transformer question
Then it becomes pretty clear that a line-to-line imbalance on the primary will translate nearly directly to a line-to-neutral imbalance on the secondary.
http://basler.com/php/download.php?file=practical....
