delete from drawing
delete from drawing
Hi, I'm a newbie.
I am working in a drawing and i have drawn and ellipse. But now i can't delete it. Its there in grey, i can't select it. its just there....but i want it gone! i think i drew it in a view and then deleted the view but the ellipse stayed. please advise. thanks.
old man neri
old man neri
RE: delete from drawing
If it does, it is linked to that view - which must be active in order to select the sketch.
If not, it is linked to the sheet - right-click on the sheet and "Lock sheet focus" to select the sketch.
locksheet focus did the trick. although i have no idea what it does.....it worked! thanks again.
Helpful for drawing schematics if you don't have Visio.
Imagine that a SW drawing is a set of windows, each with a different view on your part. The sheet itself counts as its own window. When you draw sketch curves on a drawing, they are assigned to the active view. Using "Lock Sheet Focus" or "Lock View Focus" forces SW to select from entities that belong to that particular view.
http://www.EsoxRepublic.com
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
