Aging aircraft/fatique site list
This started out as a simple google search that got out of hand! :(
Hopefully it is useful to someone.
For 1999    http://www.galaxyscientific.com/agingaircraft/agen...#
For 2000   ?
For 2001     www.agingaircraft2001.com/papers/CombinedPapers.pd...
For 2002      http://www.galaxyscientific.com/agingaircraft2002/
For 2003   ?
For 2004   ?
For 2005     http://www.agingaircraft.utcdayton.com/pages/call....
Additional materials:
RTO-MP-079(II)   Ageing Mechanisms and Control Specialists' Meeting on Life Management Techniques for Ageing Air Vehicles
Available at          http://www.rta.nato.int/Rdp.asp?RDP=RTO-MP-079(II)
RTO-EN-015   Aging Aircraft Fleets: Structural and Other Subsystem Aspects
Available at       http://www.rta.nato.int/Rdp.asp?RDP=RTO-EN-015
Assessment of Probabilistic Certification Methodology for Composite Structures : Final Report
Available at      http://www.tc.faa.gov/its/worldpac/techrpt/ar00-74...
Characterization of In-Plane, Shear-Loaded Adhesive Lap Joints: Experiments and Analysis : Final Report
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar03-21...
Damage Tolerance and Durability of Selectively Stitched, Stiffened Panels : Final Report
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar03-46...
Failure Modeling of Titanium 6A1-4V and Aluminum 2024-T3 with the Johnson-Cook Material Model
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar03-57...
Fatigue Resource Directory (FReDi)
Available from: http://human-factors.arc.nasa.gov/zteam/fredi/
Federal Aviation Administration : Aging Aircraft Program
Available from: http://aar400.tc.faa.gov/Programs/AgingAircraft/in...
Federal Aviation Administration : Aging Systems Program
 Available from: http://aar400.tc.faa.gov/agingsystems/
Federal Aviation Administration Technical Reports
 Available from: http://www.faa.gov/aar/techrep.htm
Full-Scale Testing and Analysis of Fuselage Structure Containing : Final Report Multiple Cracks
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar01-46...
Guidelines for Analysis, Testing, and Nondestructive Inspection of Impact-Damaged Composite Sandwich Structures : Final Report
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar02-12...
Investigation of Adhesive Behavior in Aircraft Applications : Final Report
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar01-57...
NTIAC Newsletter    (non destructive testing)
Available from: http://www.ntiac.com/newslist.html
Poulter Laboratory : Aircraft Safety Research
Available from: http://www.sri.com/poulter/air_safety/air_safety.h...
Probabilistic Design of Damage Tolerant Composite Aircraft Structures : Final Report
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar01-55...
Proceedings of the FAA-NASA Symposium on the Continued Airworthiness of Aircraft Structures : Vol. 1
Available from: http://www.tc.faa.gov/its/worldpac/techrpt/ar97-2-...
FATIGUE ASSESSMENT OF AN AGING AIRCRAFT'S WING UNDER COMPLEX MULTIAXIAL SPECTRUM LOADING
 Available at www.vtt.fi/tuo/33/pdf/icbmff7_ 2004_backstrom_etal_hw_wing.pdf
RE: Aging aircraft/fatique site list
I've hit many of these sites myself, but happy to find new ones.  Google is proof that sometimes, the INDEX is the most powerful tool, not the library itself.
This would make an excellent FAQ (to prevent it from getting lost in the flow of subsequent messages).
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
