Deflection of flanges in angle and C shapes?
Forgive me if this is the wrong forum to post this query, as it's not exactly a structural problem. For a given AISC "C" shape or angle, if the member is supported at its web or bottom leg respectively by bolting or welding to another rigid member, how can the deflection of either flange be analyised given a situation where there are multiple point loads on the flange in question?
Example:
Take a C3x4.1 orient both flanges pointing up then lag through the web into a concrete slab so that deflection of the member itself is neglegible. Now start loading up either of the flanges with 2 equal point loads, say equally spaced along the length of the flange.
How can one determine the deflection at a given load and/or where the stress will exceed the yield strength?
Example:
RE: Deflection of flanges in angle and C shapes?
How can one determine the deflection OF THE FLANGE at a given load and/or where the stress will exceed the yield strength?
sorry...
GNE
P
--------x------- - flange tip
/ \ L
---------------- - flange root at web
|---B---|
