Can you control the size of the circled numbers?
Hi Everyone,
Do any of you know if it is possible to control the flag size of a circled number or letter in Solidworks drawings? I tried to look for something in document settings but found nothing. I need to change the size of the flag so that my second line of text does not run through the circle. Anyone have a good idea for a work around? If so I would be very interested in hearing it.
Jon
RE: Can you control the size of the circled numbers?
You can set the flag size for "tight fit" or for a certain number of characters.  If you need more space when using tight fit, perhaps add some leading or trailing spaces or extra lines to your text.
"When everyone is thinking alike, no one is thinking very much." --Eckhard Schwarz (1930--2004)
http://www.EsoxRepublic.com
TheTick,
I know that "tight fit" controls the balloon size does it also control the size of the symbol characters? What I am trying to do is type a note that generically says " Item 1 goes into Item 2" with the 1 and 2 circled. Which I use the symbol of the circled 1 & 2. You can also type <C#-1> and <C#-2> as you type in the note dialog box to get the same thing. I would like to know if it is possible to control the size of those special symbols I have just discussed. Any additional help would be greatly appreciated.
Jon
