Finding max material number
I am writing several macros that I can use on multiple different models and would like to determine the maximum real number, element type number, and material number,  I am using *get,param,ETYP,,NUM,MAX to get the max et#, *GET,param,RCON,,NUM,MAX to get the max real#, but have found no equivalent command to find the max material number that is defined.  Is there an easy way to find this?
Scott
RE: Finding max material number
fini
/prep7
*set,last_mp
*GET,last_mp,MAT,0, NUM, MAX
*stat
Cheers,
-- drej --
matmax = mpinqr(0,14,0) ! returns max. material no. defined
matnum = mpinqr(0,12,0) ! returns no. defined materials
