Seperating a body into its own part
I have a part with multiple bodies. I want to save the individual bodies as parts, and then "remake" this into an assembly. Bottom line is, I shouldv'e created them as parts, then made an assembly in the first place. Is there a way to do this?
RE: Seperating a body into its own part
Save copies of your multi-part body and strip out the features that make the unwanted bodies.
http://www.EsoxRepublic.com
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
