"non manifold solid" error
Hi All
I am trying to perform a boolean subtract using a solid body as the target and a sheet body as the tool.
(In effect trimming a solid with a sheet)
However I get an error saying "non manifold solid" and no result.
Any ideas?
Dave
Any ideas?
Dave
RE: "non manifold solid" error
"trim body"
seems to only let me use planes or primative shapes as tool bodies.
Is there a way of using a irregular sheet body?
If you are using a sewn sheet body, it has to be continuous with no gaps. I have had no problem trimming to irregular shapes, and often use the trim command to double check that my sewn sheets are indeed continuous. Wether it is a sheet with a single face or a sewn sheet, it must be as large or larger than the body you are trimming, totally covering the resulting solid face(s).
Make sure your tool sheet body isn't tangent with any of the solid's faces where the sheet & solid first intersect....this can give you a non-manifold solid error as well.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Thanks for that clarification. Your right and it is important that the surface edges are outside the solid.
No problem, just trying to cover all the areas. It can sometimes be tough to answer a question in one post, plus different users see different aspects or approaches to an answer.
I saw that you said you sometimes use Trim Body to check your sewn sheets. Were you aware you could do this with Examine Geometry & choosing only the boundaries? If you see the number of boundaries exceeding the number of exposed edges, then you know that your sewn sheet body has holes in it somewhere & if they are big enough they will be highlighted.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Thanks for the tip! I'll try it next time. Sometimes projects get too hot to try new methods. I guess it's time for some retraining!
I think it's under Analysis -> Examine Geometry. It's a pretty simple task to use & has many other options that are a bit more technical than boundary checks.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
