varactor diode for vco application !
hi
im looking for the lowest Rs parameter varactor diode for a very low noise , wide band vco (2.5 - 3GHz).
the demands are for a :
1. 25v Br voltage diode
2. low Rs (high q) - around 0.4 ohm
3. low capacitance (from 5pf to 0.8pf Vs the Vt)
4. low cost
I saw the toshiba diodes and they look great ,but there
is no diode that meets my demands.
i also cheked the microsemi,infenion,sprague !
thanks
4. low cost
thanks
RE: varactor diode for vco application !
<nbucska@pcperipherals DOT com> subj: eng-tips
i just wondered whether someone used such a diode in the past and could spair some tips regarding the issue !?
or can recommand on a reliable company which has great
low Rs varactors .
BR
guy
Available at DigiKey, PN MA27V11CT-ND. Cost: reasonable.
Data sheet available online at DigiKey.
