extracting multiple edges in catia V5
Dear Friends,
I have imported a iges surface data in catia V5. It has nearly 100 surfaces with about 500 edges. I need to extract all these edges as curves so that i can recreate new surfaces. Please let me know the best way to extract all the edges.
Advance thanks,
Advance thanks,
RE: extracting multiple edges in catia V5
use selection filter and select all edges and then use extract command. you will get all the edges.
Amit
Amit
Thank you very much for your feedback and help.
